Well I just had an interesting time. I put the one 80W LED square flood facing backwards on it's own switch, worked fine.
It and the two forward facing 70W spot's are replacing the 35W halogen work lights my kubota dealer installed. All I did was cut the wires at the ROPS bar.
Anyway, bolted the two forward facing ones on. One works and the other blew the 20A fuse. Didn't have any more 20's so put a 30A. Blew it. So disconnected them and tried just that one light. Blew fuse. OK...bad light.
I tried 3 more, all blew the fuse.
Tested them all with an electrical engineer friend's meter. Checked voltage, current draw, start up draw, continuity, grounds. All good. All lights including the one that works measured out at 3.6 to 3.7 amp draw each.
Keep in mind I only have one red positive feed and one black ground. Hooked same feed to one light at a time individually. Lights are all on the same ROPS bar.
Took them off and the one that works, works on both sides. Other 4 blow the fuse. We have no explanation at all as they all measure out the same.
So I got a 180W 21 inch light bar, put it on and it works perfect, LOL. Very strange.
