Hello,
Is there an adjustment for the clutch pedal?
I need to release the pedal almost all of the way before the tractor starts moving. I am hoping this is an adjustment problem, not the sign that I need a new clutch.
there is an adjustment. its in the linkage. under the foot plate right in front of the clutch pedal. its a threaded rod with jam nuts. just loosen the nuts and turn the rod. how many hours are on your machine? you usually get between 2000 and 2250 on the original clutch.
