gssixgun
L3600, FEL, SnoBlower, Box Blade, Rear Blade, Forks, Cultivator, Plow
So I have searched and found just a very little info, I understand what needs to be done.. It is the HowTo that is slowing me down
I have a late 90's L3600 the Rear Wheel Tread width can range from 46" to 60" which is really nice, this is done with adjusting the Wheel mounting points and the Wheel Disc's direction..
Questions, that I can't seem to find in the manual or on the net,,
What Jack works best..
Where are the lift points..
I need to take the entire rear end in the air because I need to switch sides to bring the width down from 57" to 47"
Can I simply switch sides..
Do the tires actually need to be dis-mounted and re-mounted ie: take it to the dealer..
Does anyone have a link to actual instructions for lifting the rear end or even better a link to a Vid..
TIA
Yes I understand that normally people want to widen the stance but I am mostly working flat ground and a Gravel road so a more narrow stance will actually make everything work easier...
TIA
