Chain tensioner mod on Land Pride Tiller
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
246
87
Jefferson, Ohio
I could not keep the chain tight. You have a pivot with a jamb nut that you tighten to 400 ft. lbs. There is a 1/2" diameter rod that goes against the chain. I tighten the nut up with a 8' pipe on the wrench.
I had a friend machine a spacer for the idler sprocket.
Part #23 is the rod that goes against the chain.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
460
171
CNY
Did you just drill a hole to mount the sprocket? If so how do you adjust the chain when it wears?
I have a RTA15 series and have never had an issue with mine loosening or breaking. I only have to take up the slack every couple of years.
GBJeffOH
Nov 17, 2014
246
87
Jefferson, Ohio
I can not adjust chain. When it gets to loose I will replace the chain.
