cast iron cookery guys
timber and wine
L4802, loader, forks
Nov 1, 2026
49
46
NE WI
The cleaning mostly. I seasoned the heck out of mine and after cooking stuff like bacon there was always a bunch of crusty stuff you couldn’t just wipe out.
Also as mentioned eggs are almost impossible to cook correctly in CI probably due to the uneven heat.
Anything with a lot of sugar ( bacon) and cheese will almost always stick. A 5 minute hot water soak followed by a light scrub and it comes out easily. and don't let anyone tell you you NEVER need to wash them. After water or a light soap scrub (gasp) you just set them on a medium burner and wipe in a little oil. The seasoning is actually a carbonized oil... Almost like a polymer. Its actually pretty durable.
Scm
BX23S
Sep 28, 2024
469
437
Missouri
They only need to be seasoned once as long as you don't do something completely wrong with them. Lodge sells a plastic scrapper for those instances. or use salt when brushing
We never have problems cooking eggs. I would of thought the opposite. I thought the thickness of the pad distributes heat more evenly.
4,315
There are lots of opinions on how to treat, cook with, “season” and clean Cast Iron.
The majority are wrong.
History will help understanding CI.
When crossing the plains walking aside the Studebaker, one of the most valuable items you might have is your cast iron. You planned to stop at stream crossings or water-holes. The barrel of water on the side of the wagon was for survival of you and your animals when no water was available.
Soap was too valuable and rarely used to clean up the CI cookware.
The CI was cleaned using sand and greased with fat (seasoned) to prevent Rusting. It was NOT to prevent sticking. The CI was washed in water only at stream crossings or such. Water was too valuable to waste on cleaning a pot that can be cleaned with sand and wiped with a rag or a shock of grass. If water was ever used on it….it was heated HOT again to dry it thoroughly…then greased (seasoned) again against Rusting.
The pan was wiped before heating again for cooking….and THAT was how it was safe to eat out of...and THAT was how it was treated over and over again. No valuable water wasted…and soap was not needed to “clean” or “sanitize”…. the Heat of the Fire does that!
Moderns think that CI has to be treated gingerly while cleaning and that seasoning is to prevent sticking. Both are untrue.
To clean Cast Iron…. first it should still be warm…or it should be re-warmed… then use dish detergent and a WIRE or Stainess Steel “Scrubby”….and VIGOROUSLY SCRUB it raising suds to get rid of existing food particles, burnt bits, and grease…. Then rinse thoroughly with water…. THEN PUT it BACK ON THE FIRE…and thoroughly DRY it. After its completely dry….then a light coat of oil. (vegetable, crisco, lard, or olive or corn oil is fine. I personally use olive oil because I keep plenty of it in my kitchen anyway.)
When ready to cook with it again, wipe it with a lightly-oiled paper towel and Heat it up.
To test when it’s ready …. sprinkle a few drops of water on it…and when they “sizzle”…it’s ready for breads, veggies, meat, or eggs. ( Placing eggs on cool iron will always make them stick...as will iron that is too Hot. Sprinkle the water droplets onto the iron…and if they sizzle… it’s ready. If they instantly vaporize it’s too hot.
I prefer to cook eggs on a flat iron griddle…but a large skillet or dutch oven can be used.
First heat the iron that has been wiped with an oiled paper towel…testing with water drops…when they sizzle, reduce the flame to Low…..break the eggs onto the iron….and watch the whites solidify over the next couple of minutes. A spatula turns them gently-over. (notice no sticking)
The the yolks cook to your preference…(I like eggs over-medium… hate liquid whites… enjoy hot-liquid yolks) ….then a spatula slipped beneath will lift them off that greased iron and onto a warmed-plate. (I also can’t stand hot food served on a cold plate.)
This also works for flap-jacks, pancakes, french-toast, etc. Never put tomatoes on iron. The acid will etch and ruin the surface for the next few uses of it until the iron returns to usefulness.
After the meal, take the still warm iron, squirt some Dawn on it and splash some warm water and scrub with that stainess steel scurbby til clean…. rinse with water…then back onto the stove to make it Hot and drive-off any moisture. Wipe it with an oiled paper towel and put it away.
Trust me on this. Forget all that other crap about “seasoning” you’ve been told all those years.
BTW, I’m cooking on my great grandmothers Griswold iron as well as a 12” no-name (American) skillet I bought when first married in 1969…and also a couple Lodge griddles in 1989. They all cook wonderfully. When a girlfriend put one of ‘em in the dishwasher 35 years ago I dumped her, and it took almost a month before it cooked “right” again…but it’s still doin’ great.
Scm
BX23S
Sep 28, 2024
469
437
Missouri
WOW, I'm so thankful I haven't had to go through all that in the 14+ years of using CI. That would be a yuge turn off for me to use it too.
EPIC
KX040-5
Jul 12, 2026
30
Florida
I have found that after searing meat that a flat metal spatula will easily scrape off the crusty stuff, then wipe with paper towel.
if it is really bad, add a little water, heat it up then dump the water and wipe it out.
Really easy once you know how
5,713
To clean them I simply put some water in, and heat on high while I'm eating.
Then dump the water, give it a quick scrub, then place it back on the burner to evaporate the water.
Then when I'm walking by later, we keep a squirt bottle of White Mineral oil next to them, to spritz them for rust prevention.
I tried using olive oil/crisco/peanut oil/whatever.......The only thing those did was create a breeding ground for "fruit flies"...
We switched to White Mineral oil and never looked back.........as always YMMV 🤷‍♂️ 🍻
