CAN I PULL A 12 FT BATWING WITH A GRAND L 6060
JCALESAN
MX6000, BX2360,
Sep 7, 2022
Johnstown PA
Thinking about getting a 12 ft batwing to pull behind my Grand L6060. Would it be possible or is the tractor HP and working weight too small?
kubotafreak
Sep 20, 2018
1,049
397
Arkansas, US
For maintenance it will work fine. You will need the drop drawbar.
9,436
Which model are you considering? I have a Land Pride RC3712 on order which weighs around 3,700lb, and according to Land Pride's website it's "Kubota matched" to the MX/M models, and your 6060 is in the same class as an MX. I plan on pulling it with the M6060 but I'd like to have the option to use the MX if the situation calls for it.
The ability of your 6060 to pull the cutter will obviously depend on the terrain too.
