Can I keep ballast box up while mowing with BX1880?
AlanBauer
BX1880 with FEL, mower, ballast box
Jun 3, 2025
Washington
Hello! So I have the BX1880 with FEL and mower deck (bought 2023), and have the WB10 ballast box on back it makes my usage of the tractor SO stable around our bumpy, rolling hill 5-acres. Now that my old 1994 tractor finally died I need to use this wonderful setup to mow our property.
Is there ANY way that I can force/lock the ballast box to remain up when using the hydraulics to lower the mower deck? I tried using things with the ballast box removed and it is so unsafe on bumpy, slightly sloped terrain, and just driving the tractor the wheels in back want to bounce off contact to ground. Yes, I use 4WD or else I'd lose contnrol of tractor going downhill.
So wanting to keep weight box on all the time, how can I mow? They both run on the same system so ballast box goes down most of the way when lowering mower deck. If land is 100% flat great it still works, but any uneven ground and it will drag, scrap, or even trench a mess if you start going up a hill the back goes to the earth quickly.
I can't see a way to lock that back 3pt hitch with ballast box up. And I am not going to remove the FEL just to mow for an hour every week in our fields :) Thank you for any helpful insight from anyone who has this issue too!! Alan
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
209
212
Amsterdam, NY
On page 55 of the WSM there's a picture of how to keep the 3 pt. up while mowing. Disconnect the pins from the upper arms and put them through the holder plate. I've never tried it with the ballast box on, maybe support the box at the right height.
As far as the FEL, it only takes a 2 or 3 minutes to take off and put on if your on a flat surface.
AlanBauer
Jun 3, 2025
Washington
OK thank you for that I appreciate the start to learning something about this. Since I'm pretty new to the forum, do you refer to WSM as in I can buy the Workshop Manual (that's what WSM is?) for the BX1880 then I assume? Thanks again I'll keep at it!
Bearcatrp
Mar 28, 2023
851
489
Minnesota
I raise the mower and 3 point all the way up. Then, ease down the mower deck until it stops at my setting. The 3 point doesn’t move. Just ease the lever until the mower starts to drop.
