BXpanded Ripper Tooth
N3BP
Sep 20, 2016
506
237
Lebanon, PA
Need your help fellows. I want a BXpanded ripper tooth for my Woods BH7500 backhoe that's on my L2900. They only make them for Kubota backhoes. I emailed them and they said they don't make anything to fit my 7500. I suspect I could modify one to fit my backhoe. If anyone has a BH65, BH70, BH75, BH76, BH77, BL4690B, BT750, or BT751, could you please measure your pin spacing for me? I'd really appreciate it. The inside distance between ears on the BH7500 is 4.25'', and the hole distance between a single ear is 7''. It takes 1'' pins and I know the Kubota buckets use 25mm pins which is pretty much the same. Thanks for your help!
3,291
I have a B4690A Kubota backhoe.
Looks like the spacing of the pins is 6.5 inches, and the width between the inside of the tabs where the stick end goes is about 3 and 7/8 inches.
I went down and measured but forgot a pencil...AND you did not ask about the BL4690A anyway...but it is likely the same as the BL4690B I would think. The pins are 25mm..
If you need a more exact measurement let me know. Maybe someone else here can do better...
Nicfin36
Jun 19, 2019
1,018
470
Decatur, AL
On my BH77, it looks like 6 1/2" in contrast to your 7, and 3 14/16" in contrast to your 4.25".
Nicfin36
Jun 19, 2019
1,018
470
Decatur, AL
Henro beat me to it, but both our measurements are definitely the same.
N3BP
Sep 20, 2016
506
237
Lebanon, PA
Thank You everyone for your replies. They are much appreciated. The 6 1/2 wouldn't be too much of an issue, but the 3 7/8 is more problematic. It still may be modified to squeeze it in. Thanks Again!
