BX25D Hydraulic Problem
k9hohriver
BX 25
Jun 16, 2016
Forks, Washington
I have a hydraulic problem, the loader won't work and 3pt. won't go up, heard a high pitch sound while mowing with a brush hog. I can't find anything on taking the pump out, not sure where it is, I think under the seat, no leaks anywhere. Looks like I have to take everything off the rear to get to hydraulics?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,257
1,050
Williamstown Ontario Canada
Likely you have a hydraulic quick coupler become unseated.
From memory, your tractor normally has a backhoe.
The hydraulic flow goes to the backhoe valve and then, using a power beyond port, back to the rest of the tractor including the loader.
Do you have a hose loop which you connect when the hoe is off?
That would be the fist place I would disconnect and reconnect any couplers.
Do NOT go removing hardware as you will just make a small problem much bigger
Dave
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
The pump is in the transmission so you will not be able to get to it.
And like Dave said check the rear loop.
With the engine off, move the loader lever up/down/l/r to release any pressure.
Disconnect the loop and reseat it.
Otherwise it is on top of the transmission.
SidecarFlip
Banned
562
High pitch sound is usually a deadheading pump.
whitetiger
Nov 20, 2011
3,322
1,743
Kansas City, KS
Otherwise it is in the transmission.
The hydraulic pump is actually mounted on the transaxle housing right above the Left-Hand rear axle housing.
k9hohriver
BX 25
Jun 16, 2016
Forks, Washington
Dave
Thanks Dave! I will check out the hose loop in the rear, took the loader off.
The high pitched noise and now no noise has me wondering what's really going on.
