BX25 new leak
sagor
Jan 9, 2017
294
66
Sudbury, ON, Canada
Just noticed this leak yesterday. Never leaked there before. Checked the gear oil. While down a little bit, it only took about a cup of gear oil to bring it back up to mid point on the dipstick. That entire side of the axle seems a bit "wet" from oil, top to bottom. Other side of front axle is dry and clean. First time I removed the dipstick, there was quite a bit of positive pressure. So, I wonder what could be the cause. Any ideas? Thanks
Mowbizz
Bx25d
Aug 19, 2021
552
313
Common problem…my BX25D has been leaking for years. A while back someone suggested putting 90 at gear oil in there and it slowed down somewhat.
sagor
Jan 9, 2017
294
66
Sudbury, ON, Canada
I figure that much. Just wondering what Kubota would charge to repair. I normally use 80-90 gear oil, but I think the last service at Kubota dealer, they used the UDT stuff. Machine is due for a checkup before "winter" anyway, I might just have to bite the bullet....
It seems to have stopped/slower down. I wonder if the positive pressure in the axle (popped out when I pulled the dipstick out) had something to do with pushing out more oil.
Mowbizz
Bx25d
Aug 19, 2021
552
313
There is a fix on YouTube but it’s quite involved
xrocketengineer
Nov 14, 2020
803
725
Merritt Island, Florida
I would remove the vent/oil level plugs on top of the wheel gear boxes and check that there is oil up there. When servicing the axle, the plugs have to be out or otherwise there will be trapped air in the gear boxes that can expand. My tractor came with a very low level of oil in the front axle. The dealer sold me the 80-90 gear oil and I topped it off with that, first on the gear boxes and then I capped them. Finished adding the oil through the dipstick hole to reach the proper level.
5,748
Looks similar to my BX23s 'weeping'. Not a big deal though you need strong, angled snap ring pliers for the task. Probably got some 'grit' under a seal. If caught early, just needs cleaning otherwise replace seal and maybe the O-ring.
sagor
Jan 9, 2017
294
66
Sudbury, ON, Canada
I have a feeling some of this was due to trapped air, due to the positive pressure when I lifted the fill dip stick. I will pop open the vent plugs and check the oil again.
TECH101
Kubota - Bobcat - Caterpillar - Case - John Deere - FARM - CONSTRUCTION -
Mar 8, 2022
72
If your not mechanically inclined I would just bite the bullet and get your local dealer to replace the seal
sagor
Jan 9, 2017
294
66
Sudbury, ON, Canada
I can do the simple repair stuff, but after watching the videos, I'll pass on this self repair option. Thanks for the opinions...
