BX24 Rear Fender Replacement
kubotauser
2008 BX24 w/loader, backhoe, snowblower
Dec 2, 2016
19
Big Rapids
Hello, All
I'm a relatively new owner of a 2008 BX24. After purchasing it a couple of months ago, I discovered, among a few other issues like bad battery and bad front ball joints, the rear fender is cracked. Has anyone replaced it? The best source for ordering and any hints on DIY replacement would greatly be appreciated.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
How bad and where? I suggest removing it and having a welding shop fix it. Usually cracks come from having initial stress left that finally open it up. A competent welder will do the job leaving little if any stresses. Thin metal like the fender can be fixed.
1970cs
1,124
Grand Ledge
I believe that was the fiberglass era not the steel on the current BX25.
IIRC most of those cracked around the area of fender to platform area! And there is an update kit that was available at the time to help support that area to prevent said cracking.
Pat
anthonyv
BX24 BX2200
Jan 24, 2017
122
20
SC
I have had some luck using a lot of JB Weld if the crack is not too large. Place it underneath so as not to show. See if your unit has a step stay kit installed, this is a gray metal brackets on each side under the floor. this along with a new "improved" fender was supposed to correct the cracking. My BX24 is 2006 & you will notice you need to be careful because over time the plastic becomes more brittle.
As for the ball joints unless they are severely worn, replacement is not necessary, usually the rubber boots crack or get torn.
This is a copy from a previous post on another forum about protecting boots.
Default Re: BX Tie-Rod boot ripped
What I did for my BX24 when the boots got torn from brush, was I ordered two universal tie rod boots part #40193, also uses Massey part# 1885486M1. These boots sell for about $3 to $4 at most tractor supplies, online, & EBAY. TSC has these boots in a kit, but you have to buy 6 boots, 4 of which are not compatible & the kit is $20. Note these boots are not an exact replacement but the difference is so slight it is hard to see. They fit my BX24 perfectly & I was able to reuse the original metal retaining rings. Then so as not to have to do this again I used TECHMAN's idea of using a piece of 2 1/2in. nylon hydraulic hose covering held on with tie wraps to cover the boots. The nylon cover material can be purchased at any hydraulic hose place by the foot. Mine was about $8 for a 1 ft. piece. I used a heat gun to seal the ends to stop fraying & a soldering iron to punch holes for the tie wraps.
08quadram
bx2350d; Taylor Way 48" tiller; Farm King 50" snow blower
Apr 28, 2014
289
strawberry point, ia
Get some plastic epoxy repair. My fender was cracked on the left side where the handle is bolted to the fender. My black plastic was also cracked round the controls. Only problem now is the inserts for the bolts that hold the handle on are stripped in the plastic handle....going to have to epoxy those in too.
Mike
jcy110
BX22 with LA210 loader and BT600 hoe
Aug 22, 2015
Whitehouse Station, NJ
If you have a traveling crack, drill a small hole 1/8 - 1/4 at the end to stop it from spreading before patching it up......
anthonyv
BX24 BX2200
Jan 24, 2017
122
20
SC
New fender part #K2592-95524 is the latest version from K2592-95520 & is priced around $425. I cannot find any info as to whether it is now metal or still a plastic fender. Supposedly Kubota changed back to metal around the end of 2008 or in 2009, but as far as the BX24, plastic seems to be the only option. Talked with a kubota rep about a year ago & he was going to check if a BX25 fender would interchange & I never heard back. Cannot afford to be a guinea pig for $400 dollars plus shipping & take a chance.
kubotauser
Dec 2, 2016
19
Big Rapids
Sorry for the delayed response as I have been out of town!
Thank you all for sharing your insight. I very much appreciate everyone's input.
Unfortunately, it is plastic. The crack is on the right hand side just to the left (towards the driver seat). I wouldn't mind spending ~$400 or so if the replacement were metal, but was told by a local dealer that the replacement is plastic.
Regards to all!
kubotauser
Dec 2, 2016
19
Big Rapids
Re: BX24 Rear Fender Replacement- Update
I just talked to body shop. Showed him a picture of the crack. He said it can definitely be fixed (cost around $250). with the new around $400, I'm not sure if it is worth fixing!
