BX23S with 75 Hrs won’t crank
Waywest
BX23S, RTV500
Aug 9, 2020
11
Lakesite TN
Hello wise forum. Hoping you can assist again!!
Doing a landscape project and turned tractor off for an hour to adjust boulders. Upon returning it would not start - ie would not crank. All lights bright and dash works, glow plug light works. It is like there is a safety switch open and locking me out.
Checked:
- drive lever and speed peddle in neutral
- has gas and full clean oil
- battery charged and tender put on it
- site temperature 55 degrees
- manually inspected operator presence switches
- parking brake on
- PTO lever disengaged
What am I missing?? Scratching my head bald! Thanks
5,592
Quick connect spade lug on the starter solenoid has fallen off........
right hand side,on engine, kinda obvious, if you open the hood first....
5,592
Yeah, it nailed me too.....
I rebent the wire ,then tyrapped it to 'something'...been fie for 3 years/650+hrs.
guess there's a 'little vibration' that knocks it off...;)
leveraddict
Apr 1, 2019
905
590
NEPA
Same happened to me also! I was to the point I called the dealer to come get it. The connector was together but not all the way. I pushed it in a little more and all is well.
