Bx23s quick hitch help
Shouse2021
Kubota bx23s
Jul 16, 2021
Gerogia
Hey guys I'm new here. I jus recently bought a kubota BX23s subcompact tractor and was looking for a quick hitch. So I did some research and it gives me pics but that's all doesn't say anything else.. if I could get some advice to where to look or let me know what one I need..thanks in advance Jason
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,189
167
Hardisty, Alberta
For the best experience with a quick hitch buy one from the same manufacturer as you buy the implements you are going to mount to it. Also buy all the implements from that same manufacturer. any other way and some attachments will fit easy and others will be a PITA!
Shouse2021
Kubota bx23s
Jul 16, 2021
Gerogia
I was reading about the QH05 quick hitch it's made by landpride. But when reading details it has all thebx series models listed.. but doesn't have the bx23s listed
eserv
May 27, 2009
2,189
167
Hardisty, Alberta
If you don't do this then I recommend that you pick the attachment that you will use most and adjust the QH to suit it then adjust all the other attachments to fit the quick hitch. We sold a lot of Land pride QH's.
eserv
May 27, 2009
2,189
167
Hardisty, Alberta
I don't think the rear of the BX23s is any different than the other BX's. Should work!
Shouse2021
Kubota bx23s
Jul 16, 2021
Gerogia
Ok got
That's what I thinking. I guess I will call the kubota dealer tomorrow to see what kind of information they have cause I would hate to order the wrong one lol
Crash277
BX23S
Jan 17, 2021
844
621
I have the QH05 on my BX23s worked right away on my landpride tiller and box blade. I needed 1 spacer for my snow blower. My old finishing mower, I spun the brackets for the lower pins to the opposite sides and it fit up perfect. I bought the 05 because the lower slots fit cat1 pins with no bushings required. only thing I have that doesn’t work on it is my 3pt trailer hitch because I got the one with the top 2” receiver hole and the hook for the QH hits the metal plate at the top. I’m planning on cutting a slot in it. Anything for the 3pt of a bx. A bx is a bx is a bx. Except when it comes to rear remotes. There is a difference in the rear frame for the BH mounts. However you can get remotes to work.
Shouse2021
Kubota bx23s
Jul 16, 2021
Gerogia
Awesome thanks for the advice a information I really appreciate the picture as well
