BX23S Loader Lift Issue & hydraulics getting hot – Seeking Diagnosis Help
bans25
22
Dover
Background:
I bought a "new to me" BX23S last fall with only 220 hours. It came with a loader, snowblower, and mowing deck—but no backhoe (the previous owner sold it after not using it for his previous projects). The tractor is in like-new condition and was intended as a refresh upgrade from my weathered but trusty 2007 BX24D.
I sold the mowing deck since I don’t use it. I immediately removed the loader and installed the snowblower, along with a weight box on the 3PH. Everything worked flawlessly for snow removal all winter.
This spring, I reinstalled the loader and used the tractor lightly around the yard (mostly as an expensive wheelbarrow) with no issues. Recently, I found a like-new BT603 backhoe locally, installed it, and tested its functions but haven’t used it for actual work yet.
Issue:
This weekend, I started a digging project at my camp and noticed the loader had very little lifting capacity—though down pressure and curl power seem fine. It struggled with basic lifting tasks that my old BX24 handled easily.
I checked the hydraulic fluid level and it’s full, but I was surprised by how hot the hydraulic coupler near the fill/dipstick was. Once cooled a bit, I disconnected the BH hydraulics to eliminated that, however still had the same lift problems. At that point, I shut it down to avoid potential damage to the hydraulic system (hoping I haven’t already caused any from the heat).
I am looking for some assistance with diagnosing:
  • What could cause hydraulic functions (curl/down) work fine while lift is weak, I assume flow blockage somewhere?
  • What could cause the hydraulic fluid to get so hot? similar blockage like above?
  • Any diagnosis steps or insights would be greatly appreciated! I have a pressure gauge but I need a different coupler as the BX24D style hydraulic couplers are different than this BX23S.
Thanks in advance!
2,315
I think you need to be 200% positive that there is good flow through the back hoe valve circuit. It is often a poorly seated coupler that limits the capacity of the FEL.
I assume that there is a power beyond sleeve installed in the FEL valve and all the piping is connected correctly but you should confirm that also.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,390
1,978
WestTn/NoMs
Also make sure your 3pt control is returning to its neutral position correctly.
You may be able to find the problem area by starting the tractor cold and feel around with it running to find where the heat is being generated, probably a quick connect coupling
5,632
Background:
Issue:
Thanks in advance!
Based on that narrative my first guess woild be the power beyond on one of the attachnents is not fully connected.
TjStone
BX23MLB
Aug 13, 2025
New Florence, PA.
I am with the crowd. It sounds like a fluid restriction to me. That would also explain the temp issues with the system. The fluid needs to return properly to cool.
bans25
22
Dover
I pulled both the backhoe and loader off, drove it around a bit and the BH bypass hose on the back got hot. I pulled the hydraulic dip stick and noticed the fluid is foamed up. I drained, changed filter, cleaned screen (nothing really on it), fluid with Kubota fluid and have the same result.. what is the best way to check if I am pulling air somewhere?
5,632
Sounds to me like you have a problem on the pressure side. What is the "BH bypass hose:?
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,390
1,978
WestTn/NoMs
Remove and recouple that connector. Make sure it is completely seating. You may need to replace the coupling.
