BX23s backhoe thumb
pjoh784350
BX23, quick attach bucket, 3 point, pallet forks
May 3, 2019
168
76
Danville
On the thumb arm there are 2 pins with no grease fittings although they are pivot points when adjusting the thumb, I assume these should be removed periodically and greased to avoid rusting into a stuck position? They are held in by 2 bolts and lock nuts (not the same size bolts strangely enough). I guess I need to get a stock of lock nuts?
