bx2370 clunking fwd
7,340
What are you driving on? Is it solid ground?
Do you hear it when turning?
If so, I’d take it out of 4WD…..in my own estimation, you should only use 4WD when necessary.
bluelight16
BX2370
Sep 18, 2022
17
11
I only use 4wd when I have a full load in bucket and I get bogged down on wet soil,
bluelight16
BX2370
Sep 18, 2022
17
11
whitetiger
Nov 20, 2011
3,723
2,141
Kansas City, KS
Check to see if you have any back-and-forth play in the front axle articulation pivot. It probably needs to be tightened up.
OrangeKrush
Nov 15, 2020
1,044
517
Indy
Are you sure it's just in fwd when it does it? BX steering hydraulic cylinder gets slight play where it's mounted. It's very slight play on each end and I'm not sure you can hear it but you can definitely feel it. You can really feel it on a gravel drive.
I think my BX only had 10-20 hours when it started getting this slight thumping feel in the steering, most might not even notice.
tinkerwitheverything
bx2370-1
Jun 3, 2015
320
75
Manitoba
As whitetiger mentioned make sure the pivot bolt is tightened up and adjusted properly. Here's something else to check it's happened to me . Check your steering cylinder mounting plates. Make sure there not bent and allowing the cylinder to move around .Also check the cylinder mounting plate bolts. I've had to take the plates off and put them in a vise to straighten them out. I've actually over bent them just a bit so that when I tightened the mounting plates back up they straightend up on there own. Of course you do have to pop each tie rod end off in order to remove the plate.
bluelight16
BX2370
Sep 18, 2022
17
11
I checked the u joints and drive shaft no play or anything it does not hinder the performance of the tractor
Thank you Thank you, I adjusted the axle pivot bolt ( did not have the right socket so had to torque by feel) checked the mount plate found 2 bolts loose, retighten them took tractor for test drive even put a load of stone in bucket, no more clunking so far, I guess problem solved Thanks again
bx2370-1
Jun 3, 2015
320
75
Manitoba
Glad it was a simple fix.
OrangeKrush
Nov 15, 2020
1,044
517
Indy
I had a feeling this was what you were hearing/felt, even with the bolts tight on the brackets the slight End play on the cylinder is noticeable on mine.
