Bx2230. Help. Not starting
troysroadrunner
Bx2230
Jul 25, 2019
Carleton
Kubota not starting acts like a dead battery? All the lights go on like it's going to start turn the key not even a click on the starter. Neutral switches? Thanks
Tornado
792
255
usa
PTO isn't engaged is it? I always first look at the simple things - all the safety switches and mechanisms that would prevent a start. For my 2501 that means checking the seat safety switch, the PTO lever, and the clutch. If the pto is engaged and you try to start it, it will do exactly what you are describing. If you eliminate all the safety switch possibilities then id start looking into an actual problem.
