no glowplug dash light with key turn- won't start when cold
Turned key while meter on the positive lead of GlowPlugs and see no voltage getting to them.
Tested by putting 12volt to the GLOWPLUG (see pics in Video) positive lead. Turned key after 5 seconds and the tractor starts immediately as should.
Followed GlowPlug positive line back to dash. Followed wire to keyswitch. It was a broken connector at the keyswitch. A quick solder after cleaning and removing the keyswitch and all is fine again. Did check fuses first also.
http://youtu.be/a3NNHFNAV44
