BX2200 with LA211 FEL - How to remove
klwinter2
FEL, 60 belly mower, Backhoe, Box blade
Apr 5, 2017
Tazewell
I want to Remove my FEL to use just the belly mower,
I have removed the FEL.
I loop one hydraulic line back to the tractor and one hose is loose.
Now when running the three point hitch and deck Deck not go up and down.
What am I doing wrong?
Wbk
307
St Adolphe Manitoba Canada
Could you please re-write this article and explain if your removing the loader or installing it. if the hydraulic lines won't go on or it won't line up or whatever seems to be the problem. Thanks Barry
Wbk
307
On our BX's we uncouple the four hydraulic lines, we don't hook any lines together. I'm not sure what you mean, it must be plumbed different than ours. Could you take a picture of your hoses maybe someone will have a similar setup and be able to help you.
TripleR
Sep 16, 2011
1,911
SE Missouri
Whole different setup on the BX2200, one line loops back into the tractor.
