BX2200 steering issue
Htodd
bx2200
Jun 29, 2010
Sandusky, MI
I just replaced both steering hoses, now it turns HARD. I can't seem to bleed the air out of the lines.. Any suggestions?
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
17
Northern California
Try jacking up the front end (or lift with the FEL if you have one) and then turn the steering wheel from lock to lock several times. It should force out the air if that is the problem.
KubotaTech
None- I get to play with everyone elses stuff
Apr 1, 2010
185
PA
Turn the wheel all the way against the stop and hold it there for a couple seconds, until you can hear the hyd. pump strain. Then goto the other side and do the same thing.
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
688
196
Rising Sun, MD
Htodd.... did the advice my orange brothers gave you work.... lrt us know,,, Butch
Htodd
bx2200
Jun 29, 2010
Sandusky, MI
no, it labors as soon as you turn the steering wheel. Turning the handle all the way one way... then letting it set has improved the situation maybe 5-10% but it takes almost 30 seconds to turn the wheels from stop to stop.
KubotaTech
Apr 1, 2010
185
PA
Are the hoses installed the same way you took the others off? Be sure there are not any obstructions on the lines such as dirt, stone, plastic cap, etc.
GWD
Jan 8, 2010
792
17
Northern California
Did you try jacking the front wheels off of the ground and then trying to turn the wheels? With no ground resistance the wheels should turn easily even without any hydraulic help. If it still turns hard then you are fighting something.
From your description it sounds like it is worse than having no power steering at all. As Kubota Tech suggests, maybe you are fighting the hydraulic pump if the hoses are installed wrong.
If the hoses are new they probably had plastic inserts to keep things from getting inside. Maybe one of those caps is still in place - another hint from KubotaTech that makes sense.
Htodd
bx2200
Jun 29, 2010
Sandusky, MI
It is FIXED finally... it was a bad hose! One fitting was crimped to hard and was restricting flow. Replaced the hose, now everything works as good as new...
Thank you all for the suggestions!
