Bx2200 Starter saftey switch?
Elora
Elora ON
My tractor starts when I turn the key but shuts off when the key is in the run position. The tractor is new to me and I was hopeing someone could help me with this problem.
AlwaysSomething
BX2200
Mar 20, 2011
Richmond VA
I'm having the same problem with my BX2200.
I replaced the stop solenoid - no go. Took the ignition switch apart and cleaned the contacts - still nothing. Same with checking the fuses. The other symptom I'm having is I don't hear the fuel pump or have the battery and coil lights lit when the key is in the on position.
On the upside, it runs fine with the stop solenoid removed :rolleyes:
Any ideas out there?
Thanks.
