Bx2200 mower deck won't raise
kimbr99
Springfield IL
I have a used BX2200 with belly mower and front end loader purchased used about 3 years ago. The mower deck will not raise and the knobs that adjust the cutting height and that lock the deck in place are frozen (will not turn either direction) anyone have any thoughts
1970cs
1,124
Grand Ledge
WBK is on the right track! Two things the rate of lower knob may have closed down by accident? Try to open that, if frozen try to use penetrating oil at the base before trying to pony it. But it should move because of the recent change unless the unit has sat outside for some time?
Also the height adjustment knob should not turn till the deck is raised fully.
Pat
kimbr99
Springfield IL
Pat
We store the tractor inside although we suspect it has been exposed to the weather in its past life. We tried the penetrating oil today no luck, although I will stop trying to get the height adjustment knob to move until we resolve this issue with the other one
Grandad4
Apr 5, 2016
405
154
Greensboro, NC
Yes they do
That's a good sign... the same hydraulic system raises and lowers both the rear 3 point arms and the mower deck. At least the problem would not seem to be internal to the transmission, where repairs would be difficult and expensive.
There is a linkage mechanism going externally from the rear of the transmission to the center of the tractor that raises and lowers the mower deck. There are a goodly number of moving parts and connection points in the linkage. If the tractor has not been cleaned and maintained properly, it's very possible that dirt, debris and corrosion have accumulated to bind up the linkage. It's also possible that something in the linkage has been bent or broken or adjusted so far out of tolerance that it no longer works. Here is a link to the parts diagrams for your BX. You'll want to look at pages 223 and 226.
http://www.kubotabooks.com/AutoIndex/index.php?dir=Tractor Parts Manuals/&file=BX2200d (3meg).pdf
So a good cleaning, lubrication and adjustment/repair of the linkage may well get it working properly, although that's a messy, get-down-under kind of job. In that vein, you'll see just how that lift adjustment works and exactly where to clean and lube it.
Best of luck getting it working again.
kimbr99
Springfield IL
We are back "up" and going again! Somewhere along the way we lost 2 hex nuts on the rod that connects the linkage to the hydraulic system. When the deck was in the down position everything looked to be in place but we jacked the deck up when we were messing with it and the rod dropped loose. Once it was back in place and secured we were back in business. Thanks for the help!
