I've need to rebuild the steering cylinder but I cannot get off one of the inner tie rods. I have the tie rod that is on the side of the shaft where you can put a wrench on, off of the shaft. When I put a wrench of the shaft, no matter what I have tried, the other tie rod won't budge plus I can't keep the shaft from turning.
The small area to put the wrench on is too small and it slips. I've tried to sandwich the wrench onto the shaft by putting the tie rod back on that side and press the wrench tight against the shaft but no luck.
What I need is a way to keep the shaft from spinning when I try to unscrew the other tie rod.
I've tried to grab the very end of the shaft with a pipe wrench but the metal on the shaft is too hard and the pipe wrench won't bite in and hold it from spinning. I've also tried heating the tie rod with no success.
I need a way to keep the shaft from spinning(turning) when I unscrew the tie rod?
HELP
Thanks
HELP
Thanks
