Hello all, will be looking to purchase a new BX1880 this year and would like to know if the non drive over belly mower on this tractor is a pita to install and uninstall ? Also I notice it does not have cruise control, does that mean you have to hold down the foot pedal throttle while mowing. Seems like every bump you would be bouncing the pedal up and down maybe I'm missing something ? And last but not least can you use a small 4ft brush hog and box scraper with the BX1880 ?
I've got the previous model BX1870 purchased a year ago, but here are hopefully some helpful insights:.
I've read that some of the drive-over decks mean that the tractor may not be compatible with the Bxpanded belly shield, maybe the Brotek as well. I consider some sort of "under armor" a mandatory accessory, so I would be researching this carefully before opting for the drive-over. I purchased the smallest BX specifically because I wanted the smallest deck at 48". On a smooth concrete slab with enough room on the side to slide the deck sideways, it's not bad to attach/remove. On my 48" deck, the guide wheels don't pivot, so they can't castor to follow the sideways movement. I believe the larger decks have wheels that can be unpinned for easier sliding, though there are extra steps involved.
Cruise control was an optional dealer accessory on the 1870, but my dealer talked me out of it, saying that it was a bit crude and that I wouldn't miss it. Don't know about the crude part, but he was right that I don't miss it--the pedal layout and feel is very well designed, and I've never had an issue with my leg getting tired, or bumps causing speed issues. Maybe I'd feel differently if I were mowing a large flat field, but even then it wouldn't be a big deal.
No brush hog experience, but I'm guessing you'd be fine with a little four footer. I run a 4' box blade no problem.
