BenRich
BX1870D w/FEL, Land Pride FDR1648 Mower, Land Pride RBO560 Scrape Blade
Hey guys,
I haven't posted for awhile as everything has been operating perfectly on my 2013 BX1870.
I last mowed four days ago using my Land Pride FDR 1648 finish mower and the little BX 1870 worked/mowed flawlessly. Just previous to this mowing I had greased up all the zerks on the mower.
Today I went to mow after using the FEL to move one single load of wood chip mulch.. no problem there.
Started mowing (using the same finish mower) and saw that I was rapidly losing engine RPM (recommended engine RPM is 3142 for rear PTO). As soon as I disengaged the PTO, the engine instantly regained its RPM.
I brought the tractor back to the garage and after ensuring that the finish mower was not gummed up in any way and then going through the owner's manual I decided I would change at least the transmission filter. The fluid level was fine according to the transmission dipstick.
I changed the transmission filter and it seemed to have done the trick... for about five minutes, then the issue started again: the engine would bog down/lose RPM and as soon as I disengaged the PTO the engine would regain RPM.
This BX1870 has 187 hours on it; I bought it in April of 2013 and have religiously kept it clean, lubricated and serviced. The manual calls for changing the transmission filter at 50 hours (which I did) and then at 200 hours (done now at 187 hours).
The manual recommends changing transmission fluid at 400 hours and cleaning the transmission screen/strainer at that same number of hours.
Any suggestions as to what might be the issue here? I did notice some very fine "glitter" within what little transmission fluid came out when I changed the filter but it was not beyond what I would consider to be normal break-in type metal "glitter".
Could the transmission screen/strainer be clogged and this is bogging things down?
For whatever its worth, the tractor is stored in its own little shed and so does not sit out in any rain/sleet/snow, etc.
I'd be grateful for any advise and thanks much.
Ben Rich
Ben Rich
