BX winter prep
js5020
BX23S
Jun 27, 2018
75
PA
Last winter I had 2 occurrences of a fuel filter gel up with the BX23S and I want to avoid that this season. Which is in everyone's opinion the route to take, run fuel additives or mix up a blend of kero/diesel for winter operations?
Roadworthy
L2501 HST
Aug 17, 2019
1,647
528
Benton City, WA
I'm not sure how things work in PA but here in WA in the fall the stations begin selling winterized diesel. You could ask your local fuel supplier if they sell winterized diesel. Of course if you're using the same supply you've been using all summer you won't have the winterized diesel on hand at home.
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
X2 on checking when your supplier winterizes diesel. Use up your summer diesel now.
I use up my summer supply, and as a precaution use Power Service Winter additive over the winter. Years ago I got stuck with unwinterized fuel and I cut it with 10% kerosene, which worked fine in the relatively mild climate I live in (rarely lower than 15 deg f).
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,721
2,057
Near Lancaster, PA, USA
I've been using anti-gel additives since '91 or so and have used different brands. Never had a problem with mine.
