BX pulling a Land Plane
Bearcatrp
Mar 28, 2023
1,224
831
Minnesota
Any BX owners pulling a land plane? Am on the hunt for one but don't want to get one to large for my 1880. My 1880 is 4 feet wide. Am thinking of getting a 5 foot wide. Or should I go with a 4 foot wide so I don't bogged down. Appreciate any replies.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,852
2,276
Western MT
I have an L2501 with 6 ft Grader/Scraper GS1572. Sometimes, I have to let up on my treadle going uphill depending on how much material is picked up, but I also have a M and not just L or H.
If you were in L, I think it would be easy enough to pull the 5 ft. You can also adjust the angle to not keep as much material. The Land Pride range is 20-50. I don't know if 1880 is close enough to 20 that it won't matter.
I would go with the 5ft to be able to cover a slightly wider path and cover the tire tracks better, but it potentially has 25% material to pull since it's a foot wider. If you will make 2 passes each direction, maybe there is not much of an advantage of going with 1 ft wider.
Shawn T. W
Dec 9, 2024
599
1,064
SW Missouri Ozarks
I have 25 HP in my SCUT, and easily pull a 60" land plane ... Generally I find traction is more of a problem for me, than engine HP! And I use high range in my high/low range HST transmission.
My land plane doesn't have "rippers" though, so if you get one that does, and try to bury 4-5 of them ... You'll have a good parking brake! šŸ˜‚
Bearcatrp
Mar 28, 2023
1,224
831
Minnesota
Don't think I will need the rippers but just want to skim a little at a time. Definitely want the adjustable cutting blades. Have seen some without online. Price ranges from around $1600 and up for new. Am looking for used though. Thanks for the replies.
4,922
You will run out of traction long before you run out of power no reason a 60 incher would give you trouble
Shawn T. W
Dec 9, 2024
599
1,064
SW Missouri Ozarks
My blades aren't adjustable, that I know of ... They hang down about 1/2" now, they cut good ...
Here is a video of it in action ...
Land plane
I added 50" long 1/4" thick 2" angle iron to it, as it was cutting too deep, but with the short 32" length of runners, I wanted it longer, as I had some dips that were longer than that, so I added the angle, it's much smoother now ...
I also added a couple of little "teeth" to it out of the 2" angle iron, as I was hoping they would tear up the weeds more in my driveway (biggest reason I use it!) but they do very little! I'm thinking of cutting part of them, and twisting them a bit to see if they will disturb more of the weeds roots?
I like to go both directions with it to kill the weeds, but makes for a very smooth driveway!
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
86
75
Lakes Region, NH
I think a 4 ft land plane would be best for a BX1880. So maybe you have to do an extra pass to cover the width you want to groom. If you have hills to go up and/or areas with heavy packed material you might find a 5 ft land plane too much for a n 18 hp and relatively light weight tractor. If you just have flat land with relatively loose material then maybe a 5 footer would work.
Bearcatrp
Mar 28, 2023
1,224
831
Minnesota
Just flat land. A small incline at top of driveway. Driveway was all packed sand. Brought in 6 loads of class II. My 1st winter with my 3 point snow blower I blew at least 1 load into my yard. Dig in at uneven spots. The land plane will help me level it good in hopes to get rid of the dips I have.
Bearcatrp
Mar 28, 2023
1,224
831
Minnesota
Am seeing some land planes angle to one side, straight across, and now just saw one with one blade angled one way and the other blade angled the other way. Most I see both angle one way. Does it matter? Am seeing these on facebook marketplace.
