BX Power Steering Hose Leaking
dkforge
L2501DT, BX2670 - (loader, MMM, snowblower)
May 10, 2014
9
North Central, PA, USA
So it appears I have a leaking power steering hose on my BX2670. I can see where the two hoses are in a sleeve and run from under the dash down the left side of the tractor to the front axle. Has anyone replaced these before and if so any suggestions on how to remove the ends that are under the dash? Its pretty tight in there. Do I need to remove the steering wheel and dash?
Trying to save money by doing this myself and also to get better hoses built locally so I don't end up with Kubota hoses again that I will have to tackle this again in another two years.
Thanks for any help, the snow is piling up and I really need to get up and running again.
CountryBumkin
Sep 27, 2015
568
Central FL
Manual says you need to remove steering wheel and dash panel. I have uploaded the BX1870-2370-2670 Workshop Manual to http://kubotabooks.com/
The Steering info is in WSM_part2. I hope this helps.
