BX Add-A-Grapple
BonnySlope
BX2380FEL, Add-A-Grapple, Box Blade, Rake, Rear Blade, HR12 Tiller, Flail Finish
Apr 11, 2021
140
122
NW Oregon
Just a quick shot of Small (27") Add-A-Grapple on my BX2380. Wow, yes there will be a learning curve! But will assist in taking care of task around place. A lot easier moving brush pile then log (firewood branches) or a little better arranged.
leveraddict
Apr 1, 2019
905
593
NEPA
Pretty cool! Protect your front grill!
BonnySlope
Apr 11, 2021
140
122
NW Oregon
Size-wise, small and effective.
Thanks for sharing!
Yes it's effective, more stuff to look through when open and using bucket. It takes getting use to but allows you to pick piles and sort. Size wise it's good, allow for good bite.
BonnySlope
Apr 11, 2021
140
122
NW Oregon
Leveraction; front grill guard! picking up larger trimmed branches with one 2" limb wedging itself through fix grill guard and movable hood guard, which forced (bent) outer guard over toward loader park stand release bolt.
I didn't notice until wedge in and was able to back off. Removed guard, hard to use press to return close to original shape, still working on. I may bolt back in place and attach machinist C clap and pull off tow hitch of PU. Needs to move about .50. Surprising what a two-inch branch wedged in between steel could bend and distort .375 steel bar.
old and tired
L2800 HST; 2005; R4
This is not the OP's model but it looks like a good copy of the one I have... from W.R. Long in Tarboro, NC Prices are a hair over a grand.
BonnySlope
Apr 11, 2021
140
122
NW Oregon
132 lb isn't too bad. Thanks for sharing.
There is a video on Precision Manufacturing, a U.S.A. company. Weights are suggested and remember center of gravity.
They also call the small Add-A-Grapple a 140ibs. on video.
BonnySlope
Apr 11, 2021
140
122
NW Oregon
That must be the #114400 Model
I was just looking at that.
where did you purchase it?
Yes, that is the model. I purchased through Agfolks. was able to shuffle around a few sized Cedar 7' logs. stacking to try milling this coming spring.
BonnySlope
Apr 11, 2021
140
122
NW Oregon
Single is 155 lbs (per specs) width = 60" to 79" $995
Small is 132 lbs, width = 45" to 63" $945
Mini is 125 lbs width = 36" to 55" $895
Double is 264 lbs width = 60" to 79" $1695
plus freight, over $300 to NW, it's well-built using quality construction, complements the BX.
