BX 2230 no start after rebuild
dhbassdad
BX2230
Sep 27, 2019
Marshfield
BX 2230 not start after rebuild
does anyone know what possibly could be wrong. I put new rings in tractor, it will not start. while starting it will puff smoke out of oil cap
js5020
BX23S
Jun 27, 2018
75
PA
Re: BX 2230 not start after rebuild
Well diesels pretty much only need fuel, air, and compression to run sounds like your missing one. How far of a tear down did you do, is the cam in time with the crank? Is the injection pump in time? Do you have compression? Did you bleed the fuel at the injectors? Is the fuel shutoff valve working? Is it turning over fast enough to start?
SidecarFlip
Banned
558
Puffing 'smoke' out the oil fill cap is excessive blow by. Did you space the ring end gaps properly when assembling?
3,132
Are you sure they are right side up? Some rings are directional.
