Broke off the transmission oil filter nipple
Pawpaw
BX1800
Apr 30, 2022
Cabot Ar.
I’M LOOKING FOR A USED FRONT TRANY COVER, OR SOME ADVICE ON REPAIRING THIS ONE. BX 1800 2000 YEAR MODEL.
whitetiger
Nov 20, 2011
3,328
1,747
Kansas City, KS
Here is a used one from a BX2200D, the same Kubota part number.
eBay item number: 125177719278
tinkerwitheverything
bx2370-1
Jun 3, 2015
320
75
Manitoba
Kubota makes a nipple that you cut off the broken one flush then using a tap you thread into the housing and install the new threaded in nipple , specifically for the BX. P/N 15241-32290 . I believe instructions etc: come with the kit.
Jul 25, 2021
I saw this a couple years ago so hopefully this will help you fix yours.
Kubota makes a nipple for repairing this on BX models. p/n 15241-32290
The solution is to order a pipe joint from Kubota! The P/N is 15241-32290. One end is M18X1.5 and the other fits the hydraulic oil filter. Now for the nerve wracking part - Cut off the aluminum filter nipple as close as possible to the flange, I used a Dremil with a fiberglass reinforced cutoff wheel. Drill out the existing hole to 21/32". You drill it about 1" deep (mark the bit with tape), you will know when you are deep enough when you see the hole open into the oil cavity behind the nipple. The top of the hole will be into the cavity the bottom will have metal left over - this will be obvious as you drill. Remember to coat the bit with grease so you pull out most of the chips. It is critical to drill the hole as square as possible, too much of an angle and the filter will not sit square enough to seal. I eye balled it and it worked, no fancy tools required. You should now make sure that any remaining nipple is shaved off even with the back plane, I used a sharp wood chissel, works fine on aluminum. Next you tap the hole, I used a 4 flute tap. Once all the metal debris creating steps are done you should pull the caps off the oil filter chambers (allen head caps to the left of the filter). The upper one is 6mm the lower is 8mm allen - there is a spring behind the lower one), flush out with brake clean. Now screw in the Kubota nipple using high temperature red loktite on the threads. You can tighten the nipple using a 24mm socket. Screw on the new filter, fill with oil, modify the existing shield to encase the oil filter ( prevent anything from hitting it in the future) and you are done. I realize that pictures would really help this description but I was not thinking of posting this while I was doing the job.
Japajaski15
L3710. Bx2200
Apr 15, 2025
New York
Did you have to use a different filter or modify that kubota pipe joint? I read somewhere else that the pipe joint you listed wouldn’t allow the hydro filter to thread on because of the nut to screw the pipe joint on and being threaded differently. Trying to figure out how to fix mine currently.
bx2370-1
Jun 3, 2015
320
75
Manitoba
I don't know . I didn't have to do this ,this was just something that I had seen on line. However I'm sure if you found a nipple with the proper threads you could still do the repair . If you figure out what to do and what works could you post the fix for others to see as well . Thanks
