Brand new water pump
johnfrazier99
Bx23 MLB
Jun 7, 2026
Maryland
Hello again!
back in June I thought my water pump had went bad in my bx23 mlb so I replaced it only to find it was the lower radiator hose that had a nick in it. All was well until September when I started noticing the same puddles. Where the pump connects to the pulley then the fan is where I now have fluid leaking from. Attached is a picture. Like I said brand new pump and seal and lower hose straight from messicks.
4,295
When you replaced the pump…. did you also “flush” the cooling system..? …and did you use a commercial cooling system flush or cleanser..?
