Box Blade 48 or 54 in.
scattergun
Kubota 2008 B2320, Kubota 2014 RTV 1140
Jul 25, 2017
37
Troy,MI
Looking at purchasing a box blade for my B2320 Kubota and was wondering what size and what brand manufacture do you recommend.
I'm like a deer in the head lights this tractor stuff is all new to me. I only want to do it once and do it right thanking you in advance for your help.
Bmbbm
Bx2370 land pride box blade 60"mmm kubota fel
May 29, 2016
282
Chillicothe mo
My very knowledgeable dealer recommended an 48" box blade for my BX2370 stating I would run out of traction before I ran out of power. Your B series tractor is enough heavier I would think it would handle the 54" just fine. As far as brand there are several good one's out there. Really not that much to one. Make sure it has a bolt on replaceable blades. Weigh is also a good indicator of quality, with heavier being better.
3,410
Keep in mind that the wider box blades will level & average large areas better, and narrower box blades dig better. It's a function of surface area; it requires more down force (weight) to drive the wider blade into the ground that the narrower one. If your main use will be digging, contouring, or cutting water courses, consider the narrower box. Besides the wider box is easier to hit things with, as my neighbor found out last week when he hit the corner of his new huge metal building. (one week old) The B2150 cleared, but the 60" box blade didn't.:(
My B7100 with a 42" box will dig circles around his B2150 with a 60" box.
Missouribound
Jun 17, 2014
657
54
Missouri
I too have a B2320 and I bought a 60" box blade with it.
Works just fine. I use it for grading my driveway and filling holes in my yard.
From what I understand you want the BB to be at least as wide as your tread width so you won't have to drive in the freshly leveled area.
scattergun
Jul 25, 2017
37
Troy,MI
Grading my drive way is what it will be used for the most its 125 yards of packed gravel. Thanks for all your help looking forward to playing in the dirt
NoJacketRequired
May 25, 2016
444
81
Ottawa, Ontario
I have a 60" box blade on one B7510 and a 48" on the other. Both work just fine, but I can pull a bigger pile of gravel with the 48" box blade. The 60" blade is a lot nicer to work with as a result of its extra width, just a lot fewer passes to get the job done.
