Blown hose, replacement confusion
OverkillTASF
Kubota M5660, WR Long UJ1 4-in-1 bucket, Titan Cat2 Ballast box
Nov 25, 2020
9
First... The story. On my M5660SUHD with WR Long 4 in 1 bucket, purchased less than 2 months ago at the dealer... I crushed and blew the hoses on the bucket that open and close the bucket. Took them off and gave em to the wife to stop by the dealer to check on replacements.
My expectation was to pay around $30 per hose. The specs as I saw them were... 5000 PSI, 3/8", 3/8" female something on one end, 1/2" male something on the other, 4'5" end to end. I could not find this makeup at TSC, but it seemed attainable online generally depending on what the actual threadforms were.
Wife returns with 2 hoses. 3000 PSI rated. And the following statements from the service guy:
- "We only have one type of hose here, it is 3000 PSI on everything even the big excavators and skid steers"
- "I don't understand why the bucket manufacturer put that hose on there when the tractor's max PSI is like half that"
- "The old threads where it connects to the bucket had tape on them - the new threads don't. We are trying to get away from that due to contamination."
Anyone else have issue getting hoses from your dealer? Looking around my tractor, all of the hoses are 5000 PSI except for the lowering ones on the main boom. It sounds like I can't count on my dealer for these replacements. That's pretty disappointing given the reason I chose Kubota was dealership proximity... They didn't even have the right size grease nipples in stock...
Re: 5000 PSI: While it's true that my tractor pump can only generate 2800 PSI... That doesn't mean that grabbing a slightly lopsided tree that's trying to force my jaws open is going to generate less than that. Isn't sizing the hoses based on what the pump can output kind of a rookie mistake? I feel like there's a damn good reason WR Long went to the extra expense to put 5000 PSI hoses on there, and the tractor came with the 5K hoses already on the loader itself too. There are more forces at play than just what the pump can do, right? I do wonder about hoses as a sort of breaker... I wouldn't want some twisted tree puling on the bucket to nuke my valves or something, I'd rather it pop a hose... What's the right play here? Surely the manufacturer knows what they're doing?
Fitting-junkies, fact check me here... The male end of my hoses was billed as "Male NPTF Pipe Swivel". This is the end that was previously taped, by WR Long, on the 4n1 bucket. My understanding is that NPTF fitting do not require tape because they're meant to deform the threads slightly and form a mechanical seal between the metal. NPT however requires some kind of tape or sealant. Isn't it likely that I have NPT threads on the bucket, and now that I have a "no tape needed" NPTF thread on the new hoses, I'm connecting NPTF to NPT and therefore will still need some kind of sealant / tape?
And finally... The bill for two hoses:
8 feet of 387TC-6-RL 3/8" 3000 PSI hose @ 5.75 each = $46
2 female JIC 37 swivels @ 8.20 each = $16.40
2 male NPTF pipe swivels @ 20.95 each = $41.90
$104.30
That seems like a lot of dealer markup... checking on a local-ish (1 hour away) hose co's website it looks like I can build a 5000 PSI hose with these fittings (though I'm not sure if it's NPTF or NPT) for $21 each! Seems like it's in the ballpark of TSC's various hoses too.
Finally...
Would it make any sense to replace fittings / install adapters to make sure my hoses use some more... standard/better... fitting? Like JIC swivels or something... Not sure if one thing is more common / easier than the other. Especially on these 3rd function hoses that I feel like I'm gonna tear up a lot.
i7win7
Feb 21, 2020
3,377
3,988
Central, IL
Take old hose to NAPA they can make a custom replacement hose. May also have fittings for off the shelf hose. A custom hose can be better protected from damage on something like a backhoe or skid steer. FEL or 3pt implement where hoses are easy to replace - use off the shelf with adaptors (adaptors seldom fail).
3,322
I don’t personally think $52.15 each for hoses that the dealer will guarantee to fit and work is particularly outrageous, and the reported comments are good as well. You should NOT use tape on hydraulic fittings for the reason stated. WR Long may have simply used 5K hoses because that‘s what they buy in quantity and it’s “overkill” for your bucket, Overkill. The 2-hr roundtrip to the other hose outfit (that you cannot determine if they actually have the correct fittings for) might be the real waste-of-time-and-money when you get them home and can’t use them. IMO
While it’s true that NAPA custom-makes hyd hoses... they aren’t cheap. I had a 3’ 1-inch hose made up by them and it cost twice as much as the local CarQuest charges ($140 vs $72)
OverkillTASF
Nov 25, 2020
9
I wouldn't mind paying a _little_ extra from the dealer for that "made for your machine" feel... But with 5K hoses / NPT fittings as OEM on the tractor it feels wrong that the hose guy would be a better engineer than the manufacturers and sub in 3K hoses / NPTF fittings... and then leave the couplers hand tight so I could decide how tight I wanted them to be... Certainly doesn't lend me that "made for your machine" feeling...
I am using this machine for a lot of woods work, pushing down trees, pulling them out to saw them up, carrying them to the burn pile. I anticipate snagging / smashing hoses more often than usual (especially the ones on the bucket since they're so exposed) and don't mind a little trial and error figuring out cheap replacements, especially if the local dealership is just "using what they buy in quantity" and overcharging.
I had skipped going to TSC for this because the premade hoses weren't 5k (4k), exactly 53" (48"), or with exactly the right fittings. But 4k is better than 3k, the dealer hose is 48", and I can grab some adapters from TSC... and the TSC hoses are $17. And it's closer to the 5K PSI that the manufacturer put on...
I'll have to hit up NAPA as I do have those nearby, see what they've got. Hopefully it isn't nuts.
Really do want that "made for your machine" feel back!
SidecarFlip
Banned
557
I don’t personally think $52.15 each for hoses that the dealer will guarantee to fit and work is particularly outrageous, and the reported comments are good as well. You should NOT use tape on hydraulic fittings for the reason stated. WR Long may have simply used 5K hoses because that‘s what they buy in quantity and it’s “overkill” for your bucket, Overkill. The 2-hr roundtrip to the other hose outfit (that you cannot determine if they actually have the correct fittings for) might be the real waste-of-tie-and-money when you get them home and can’t use them. IMO
Gotta pay for that Weatherhead crimp machine, they ain't cheap.
SidecarFlip
Banned
557
Actually, you can but with caution and that is, don't get the tape over the open end at all because it will get into pumps and stuff and screw them up. I use the blue tape but I never put it past the last 1/8" of the male fitting. I prefer 3 Bond or DDEC sealant but I've used tape in a pinch.
3,322
You appear to have misunderstood what I wrote... I was suggesting that W4 Long is who bought in quantity...and their 5K hoses are overkill...but that’s what they had in-stock when they made your hoses. Sorta like using a Grade8 bolt on a lawnchair... overkill but what was on-hand. That doesn’t mean YOU have to intall 5K rated hoses...and if you’re worried about physical damage from tress/brush to your bucket hoses... their psi-rating will not prevent that...you’ll just have paid more for unused psi capability. Do you have ten-ply tires on your car? ;)
1,712
Use sealant since you’re unsure of both thread forms. It is required for NPT to NPT, NPT to NPTF and won’t bother a NPTF TO NPTF so is safest way to go.
OverkillTASF
Nov 25, 2020
9
No I didn't misunderstand, I just don't understand why you'd expect only WR Long to use what they have on hand and bought in bulk..... Seems like the dealership could also just be "using what we buy in bulk" .I've also got 5K hoses all over my Kubota loader - put there by Kubota. Do they _also_ needlessly install 5K hoses?
What's more likely... a manufacturer buys more-expensive 5K hoses in bulk and installs them unnecessarily... or a dealership buys less-expensive 3K hoses in bulk (As they said, it's all they install) and install them, overcharge for them, and have more business replacing burst hoses?
Call WR Long 252-823-4570. Problem solved.
I will do that... but I have to travel out of here in order to get cell service for calling. Yay rural areas!
Can you find the manual for your machine and check specs online?
My tractor's pump is rated for 2800 PSI. But your hoses can and will see some higher pressures than that:
Imagine grabbing a log on the ground with the bucket... you bite as hard as you can, use all 2800 PSI to dig in. Then you lift. That heavy log trying to get out of the jaws, especially if it's not perfectly balanced, can exert more pressure on your jaws than the tractor is able to pump out, right? I'm not sure if 3K hoses can serve as a "breaker" to prevent damage to your bucket valve or what... but with 5K hoses all over my tractor (put there by Kubota!) I'm expecting there's more to sizing hydraulic hoses than just looking at what the max your pump can do...
Do you have a sealant you prefer? I was looking at Gasoila because it's cheap, readily available, and supposedly ok for hydraulic fittings.
4,555
The one time I’ve had a hose blow on my L, it was a Sunday afternoon and it’s kind of a long boring story why but if I didn’t have it functional by 8am the next morning it was going to cost me about $1000 extra on a driveway job. Dealer was closed. NAPA 20 minutes away was only place around that was open and it was an hour before they closed. Took them the old hose, they made a replacement. Put it on and all was well. It was $55 but at that point didn’t care what it cost. Did zero research, no thread seal, no figuring out if they’re NPT, NPTF or what; just screwed on the the new hose, topped of the fluid and kept running. It worked out, but less than ideal. If you need it and need it NOW it reduces your options on cost and specs.
If I had hoses that I was thinking are at risk for semi-routine damage, I would take the time before they blow to: 1) ponder on whether there’s some way to reroute or shield the hoses to reduce potential for damage; 2) if that’s not practical, research the most cost efficient source for correct hose (especially if I was really particular about the detailed specs v “something that works”) and have at least one spare on the shelf at all times. Same reason I have a spare tire in my car and truck.
1,712
[QUOTE="OverkillTASF, post: 427384, member: 44756"
[/QUOTE]
Not really just use one you feel is adequate
OverkillTASF
Nov 25, 2020
9
Was able to make a call this morning - Spoke with Josh at WR Long. Yep, they're of the opinion that 3K is sufficient as well. Say there is a shortage of supply of 3K hoses so they've been using 5K just to get stuff out the door. You got it on the nose!
