blowing seals
mcdee190
21
acworth ga
I have a BX25dbl tractor with a BT602 backhoe...the backhoe control valve has a pressure relief valve for the swing function of the backhoe and after 30 minutes of use it blows the Teflon seal at the end...pressures are 1700 psi...slightly below specs for operating pressure...50 psi on the return side. Any ideas on this would be appreciated.
