Block Heater
apn73
B4200 with RC44-42 belly mower and FEL
Jul 26, 2011
32
SE VA
Hello All,
I have see references around this website/forum about magnetic 1500 watt heaters that you stick onto the oil pan of your tractor and use that cold weather block heater. The largest I can find is 300 watts, can someone send me a link to one of these 1500 watters?
Thanks,
Adam.
birddogger
433
Pittsburgh
I'm seeing the same thing you are finding.
If you think about it, 1500 Watts is about the same as a burner on an electric stove. Would you really want to leave that "on" under a pan of oil?
I've seem some higher Wattage "frost-plug" heaters. There, there is no fire hazard, and the circulation of the water would spread the heat around.
apn73
Jul 26, 2011
32
SE VA
Totally get what you're saying, but magnetic heaters that I have found have had a thermostat control.
Ancbill
Bx2360, 54" mmm, BX2750D snowblower, RB0560 rear blade, psycho border collie
Dec 17, 2011
49
Anchorage, ak
I too have a block heater. I set it up on a digital timer that I got at lowes. Works great, I have it go on every morning In time for me to clear the drive before work. Also goes on just before I get home. It really heats the entire engine even in below zero temps.
