Black smoke power loss
Tooljunkie
May 13, 2014
4,150
35
Black smoke power loss and now it wont start, does it seem to turn over normally ?
Injector gone bad, or injection pump developed an issue.
Ramfan781
Bx1500
Sep 26, 2016
12
Angier
Yes it turns over great. Just wasted 60.00 on glow plugs:mad:
Is there any way to check the injector or pump ?
Tooljunkie
May 13, 2014
4,150
35
There is a lot of things, low compression is another thing to consider. It may almost fit your problem too, like a blown head gasket or valve adjustment.
Not easy but removing injectors and checking spray pattern would be on my list. Adjusting valve lash is another. Im grasping at straws here, but my preference is start with the cheap/inexpensive stuff first.
Compression testers arent all that expensive, but expensive enough to make it hard to justify for a one shot deal. Perhaps renting one or maybe an aquaintaince has one he could do the test for you.
9,118
Have you removed the injection lines from the fuel injectors to see if they are spurting fuel when cranking the engine over?
Ramfan781
Bx1500
Sep 26, 2016
12
Angier
Pulled tractor in the garage. Work has my time limited. Thank all of you for your help. It will be a cple. Weeks before I get a chance to work on it. I will keep you update on next move .
Ty darren todd
