Best snow tires
Rixhd11
Kubota B2410 Loader, Blizzard 54" 3 point hitch rear mount blower
Jan 13, 2022
Rutland,MA
Currently running turf tires 33x12.5 - 15 on B2410. The driveway is steep. Past couple years the tractor won't go up driveway pushing rear snow blower. Could the tires just be too old? Tire recommendations?
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,977
2,357
Western MT
Not tires, but chains. It's more likely that your road is just slicker this year due to snow/temperature differences.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
530
Benton City, WA
Turf tires really aren't very good in snow whether new or old. Get a set of decent chains. If they're not hardened they'll wear out pretty quickly.
lynnmor
B2601-1
May 3, 2021
1,817
1,621
Red Lion
If you are concerned about scratching the driveway, get rubber tire chains. The only negative with them is that they do not help side to side, so if you have considerable tilt in the surface, they are not for you. I have one spot where I did a 180, now I approach that with more care.
old and tired
1,919
1,297
What PSI are you running in the tires? Maybe try letting some air out which would allow more of the tire to be in contact of the ground.
jyoutz
Jan 14, 2019
3,626
2,719
Edgewood, New Mexico
Steel chains shouldn’t affect a snow covered driveway.
lynnmor
B2601-1
May 3, 2021
1,817
1,621
Red Lion
Since the idea of plowing or snow blowing is to remove the snow, the steel chains will contact the surface. If the tire spins, the steel chains can really make marks that many would not want.
jyoutz
Jan 14, 2019
3,626
2,719
I’ve never removed snow down to the bare road surface. I guess some people do.
