Belly mower
dotty
2008 Kubota L3400D 4wd, 1992 Kubota B7100 HST, 1977 M-F 230 Diesel, 1949 Ford 8N
Aug 10, 2013
14
Indiana
I own a 1992 B7100 HST with a 60 inch belly mower that I am getting ready to have front end loader mounted on. The dealer/installer told me that most belly mowers can be locked in the raised position so the 3 point hitch can bre used for other implements without remover the mower. I don't have a manual so I'm not sure how to do this.
Thanks
mickeyd
Mar 21, 2014
1,192
Guin, AL
Dotty, go to kubotabooks.com and download both the users manual and service manual for free.
What part of Indiana are you at?
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
If you look under the area roughly under your feet, you may see a small metal strap hanging down with a hole in it. Should be one on each side. Then look for a part on the bars that go up and down with the action of the three point. See if there isn't one of those lower bar holes that lines up near that first mentioned part. A bolt through the two with nut on it maybe the way that locks up.
