battery charge circuit B7001
stuart
B7001 with loader & tiller, 3 point hitch and 4' rear blade
Aug 9, 2009
280
Aldergrove, BC, Canada
The battery on this beast has reached the point where it won't hold a charge overnight, so that is a straight forward replacement. Before I put I new one in. I would appreciate a bit of info about the charge circuit so I know if it needs an overhaul at the same time.
1 - I understand this is an unusual generator, but I can't find the thread where this was discussed. Can anyone help?
2 - running at about 1/2 max rpm (no tach on this one) I was only getting about 1.5 amps into the battery. Battery was not fully charged at that point, was just up enough to start the engine. What should the rate of charge be?
Thanks
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
This may be what your looking for ?
Dave
http://www.orangetractortalks.com/forums/showthread.php?t=526
