Ballast Box Dimension
aim4gold
B3200
May 23, 2011
22
NE Kansas
If you were building a custom ballast box for a B3200 (500#) how far from the bottom would you center up and place your bottom arm pins?
Eddie Jr.
B3200 HSD
Mar 27, 2011
152
Ottawa Valley, Ontario, Canada EH!
Do you have a rear implement? I was offered a ballast box from the dealer with the purchase of my loader, but I opted for the discount as I was buying a rear blade that works very well for rear weight. The box blade I recently acquired is even better at almost 500lbs 2feet back of the tractor.
4,836
Sounds like a deal, what I am useing is my land pride rear blade only about 150 pounds but works ok on my little bouta but then I have the tires filed with 50/50 anit freeze and wheel weights too. I was useing an old washtub filled with cement on the 3pt on the old cub it worked but werent real purty,,lol
aim4gold
B3200
May 23, 2011
22
NE Kansas
A rear scraper or any rear implement is fine for ballast but now you have to watch out for one more thing when backing and turning. A compact ballast box with tool holding features is the way to go.
I want to keep my cg as low as possible so I was thinking about adding pipe legs to the 4 corner of the concrete ballast box that I could drop down when I want to unhook.
