Hey, folks. I'm trying to get my B8200D working. It's rusted all over the place, leaking in a few spots, and most of its electrical system was chewed up by rats (on top of bunch of patch jobs over the years before I got it). So, I set out to completely rewire it as one of the first steps.
Problem is that a lot of the wiring was in horrible shape and some parts were missing completely . I was able to get some of it working. From the schematic.jpg attached to this post you may see what's been done (colored areas indicate completed portions) -- the only things I left out are: hazard unit, hazard lamp switch and all of the rear lights (my tractor doesn't have a fuel gauge, so that's left out as well).
I'm able to start the tractor and confirmed that the battery is charging from the dynamo, but I'm running into a few issues:
1. Headlights won't turn on (less important for me at the moment).
2. CHG and OIL lights are on as soon as I connect the battery -- not even putting key in (pretty important to get this fixed).
So, it appears I messed up something with either wiring up those lights or there is another issue. One area that confused me was the voltage regulator.
Per the diagram (see schematic.jpg or regulator_schematic.png), going to the voltage regulator we have:
1 green wire
2 grey wires (I used pink, based on what I had)
1 red wire
1 black wire
1 white wire (I used red here as well)
On the regulator side, we have:
1 green wire
2 grey wires
1 red wire
1 black wire (ground that gets attached to one of the bolts on the regulator)
1 yellow wire
Does white wire (red in my case) get connected to the yellow wire? Does anyone have a B8200 and care to share a picture of those connectors and their wiring?
1 green wire
1 red wire
1 black wire
1 green wire
2 grey wires
1 red wire
1 yellow wire
