B8200 Speed Selector
Kubotaman41291
Kubota B8200, 1995 Dodge RAM 1500 5.9l V8 4x4, 18 ft. flatbed trailer
May 13, 2011
22
Murfreesboro, TN
How do i change the speed of the PTO? is that on the same lever that turns the PTO on? or is there another lever that i am missing? suggestions?
Billy13
L2250, B8200
Feb 2, 2011
31
Choctaw, OK & Boardcamp, AR
There are 3 positions on the PTO selector. The center position is neutral. Pulling back will place it in the 540rpm position. Forward from neutral puts the PTO in the 748rpm position. You will want the 540 position for most attachments you will be using.
I'm not sure of the high speed rpm numbers since mine is worn a bit.
76_Bronco
B7200 4WD w/FEL, 4' disc, 4' Brush Hog, 14" Plow, 4' Blade, JD 246 2 row Planter
Mar 28, 2012
182
Rainsville, Al
mine has a little bracket on it that prevents it from going forward.
So does my B7200, actually the bracket on mine is welded in place. I don't know of any american implements that use anything other than 540RPM's so I'll leave it in place.
kubotasam
Apr 26, 2010
1,211
134
Alfred Maine
I often use the 786 rpm on my B7100. It really helps my snow blower work better. I use it on my tiller also.
