Hello everyone,
I bought a Parker Racor 120AS diesel filter assembly to replace the factory filter so I can check and drain any water easier on the B7800. I will also install a shutoff valve before the filter.
The inlet and outlet hose barbs were easy to find (1/4 NPT I believe), but I can't seem to find an angled fitting for the vent connection (it's not 1/4 NPT and also not 3/8-16... maybe it's something metric ?)
Would the new filter work fine without a vent connection? I am guessing the original connection at the top of the filter is a vent connection. I have seen some videos of this being installed without the vent connection, but on different equipment.
Also, would it be correct to assume that the fuel would come in from the fuel tank on port 1 on the Racor and leave on port 4 to the fuel pump?
Thanks,
George
Thanks,
George
