B7100HST with 219 loader
Big Kahuna
Kubota 2000 L3010 HST with Loader ,1992 B7100HST , 1979 B6100E & 2007 F2880
Dec 23, 2011
369
9
Homer City, Pa.
1982 Kubota B7100 HST 4 X 4 One family owned, 1509 original hours on working hour meter, tractor functions all work as they should.
small restoration done in 2012 to loader and rims. All new Carlisle tires, new fuel tank, new lines, new fuel filter housing, new seals in injector pump, new fuel injector lines and injectors, radiator redone, tank was leaking, new hoses and belt, new hydraulic cylinders with all hoses, N.O.S. control valve, used but never abused, very strong workhorse. THE WEIGHTS DO NOT GO WITH THE TRACTOR.
Please come out and look, cash only $100 bills. In this sale you will receive the original cylinders, control valve and seat.
The reason I'm selling this one, I have 5 Kubota's
Look at the frame for the loader, it's 3/8 thick, nothing cheap here and it's a Hydro.
This needs nothing
This is when Kubota built a tractor, no plastic and with parts available who's to say how long it will last, it's 36 now it might go another 36? The loader is a B-219 with crank driven pump, the pump is rebuilt and the drive is new from the crank to the pump, the right side tower support is the oil reservoir and holds about 8 quarts and the bucket is the larger 48 inch which the bottom is strengthened and I added teeth which are replaceable. Each back tire is 12 1/2 wide and the rims are set all the way in, so you can pull them out more if you want more stability.
Asking $7000 Firm on price, Location Indiana, PA. 15701
