B7100
TW5447
Daleville, AL
Does the B7100 have a water pump? If the oil pressure light does not work, any suggestions on how to make sure there is oil pressure? Can the oil fill cap be removed and look inside while engine is running? I know on some car engines you can see oil moving around in the rocker arm area. What type of pto shaft does it have? Is it a 1 3/8" with 6 splines? Does it rotate clockwise or counter clockwise? Just trying to get an idea of what to look for when I go back to check out the B7100. I know I must check the hi/lo and fwd levers. They have a piece of wire around them holding up the bottom one I assume. How about checking for water in fuel system? The fuel bowl looked dirty for sure on the outside. Can the sediment bowl be removed for inspection?
The more I read about this model the more I like it. I want to be sure as possible I do not miss any major problem that could be costly to fix. Thanks for all the info.
