Got the tractor split and removed the rear main seal cover to replace it while it was apart. Ordered the new RMS # 19215-04460 and popped the old one out. Got the new seal today and it is too large outside diameter and does not fit tight around the crank. Did this part change or something?
Help
I also marked the flywheel before removing but in the cleaning process removed my sharpee marks. Anyone got any ideas on putting it back on correctly? I assume since it will bolt up in any position that it would not matter but the timing marks would be useless in the future. Any help on this also appreciated.
Also, would you use the black rtv on new gaskets when reinstalling or just use the gasket? Oil pan, etc
thanks.
Help
thanks.
