ck21084
L3200-DT, LP 1672,B7100 enrossi 5ft finish mower, 7ft backblade, 20"subsoiler
First off let me say thank you for all the valuable information on the forums.
I have a B7100D that is primarily used for mowing about 3 acres on the weekends. When I purchased the tractor it had a 48" mmm that was belt driven from the front pto with the electric clutch. This unit worked well with the exception of the cut quality. In most grass it would bog or miss areas of grass.
Because of this I recently purchase a 60" rfm from a fella on Craigslist. The brand was enrossi ( not much info online about them) and the cut difference is night and day. This rfm is a bit more tricky to use in tight areas but once your use to using it you can make the deck swing around trees very easily where minimal trimming is needed. So far I am very happy regarding this.
Does anyone have experience with this brand?
Chris
Chris
