B7100 Dyno Factory Specs ???
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
Does anyone know what the output (in amp's) spec's are for the Dyno on the B7100 ?
I'm wondering if I can make it work with the existing dyno with my additional lighting.
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
I run 4 55w halogens for 20-30 minutes at a time and have never had a problem.
Remember, your charging system is a SYSTEM and not a single component.
tmessenger
B7100D P
Feb 17, 2013
40
Fairfield, IA
I have an amp gauge on mine, it puts out 9A at 14v when the engine speed is up so around 125 watts.
Tim
Dan_R_42
Dec 1, 2010
447
Taunton, MA
Tim
COOL, Thanks Tim. Just what I needed to know.
Where did you pick up the amp gauge?
cb750k8
B7200HST D 4X4
Aug 23, 2013
101
Dublin, Ireland
Manual/Specification on my B7200 gives this;
Starting system Electric starting with cell starter (12 V, 0.8 kW), glow plug and decompression device
• AC dynamo 1 2 V, 150W
Battery 12 V, 45 Ah
150 Watts is the answer on a B7200 the 7100 is probably the same.
I am running 2 * 55 watt lights at present and intend to up this to three * 150 Watts
Hope this helps
Cheers
cb750k8
B7200HST D 4X4
Aug 23, 2013
101
Dublin, Ireland
Apologies
My earlier post should read as follows. (3 * 55watt not 3*150watt)
I am running 2 * 55 watt lights at present and intend to up this to three * 55 Watts
Cheers.
