B7000 cold start rod
kaze
Kubota B7000 Cub Cadet 1782 Cub Cadet 78D York Three point rake Woods RM 400 mo
When I bought the tractor the cold start rod was missing.
When I adjusted the valves the cold start assembly for both cylinder were brazed together on the underside of the valve cover.
The springs for the two are ok
If anyone has a couple of photo's of the rod from behind the steering wheel to the two operating levers on the valve cover.
Would it be possible to take a photo and send it to me so I can make a cold start rod??
Thank you
Joe
kaze
Had a stainless steel rod from another project just bent both ends drilled for cotter pin at the valve cover and good to go. Thank all
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,257
1,050
Williamstown Ontario Canada
NIW has previously said the decompression feature was from an era where battery performance was marginal compared to today's batteries.
It is no longer needed!
Dave
